Overdriven
Destroyer of Tires
Overdriven's Avatar
08.05.2011, 11:35 AM
I wouldn't recommend using alloy posts & towers, that will indeed increase the chances of bending the towers. Use short plastic posts and alloy towers for best results ( long posts in any material will be prone to bending or snapping... ).
Otherwise you can make your own from some nylon rod the correct diameter & cross drill it for the mounting screws and body clips ( 2mm drill bit should do the trick ).
The aluminum rod I used for the towers wasn't the best quality stuff and was definitely weaker than the New Era towers I had. But good looking out and I really like your nylon rod idea anyway. Easy to work with, no worries that it'll bend or break towers and it should be alot cheaper in the long run compared to buying posts made for a stock truck.
