08.06.2011, 08:24 PM
Linc, make sure you aren't using acid flux....that's not good for electrical connections, and if you used it for pipes before, it probably is acid.
I use 60/40 rosin core solder. Decently thick so it has a good amount of flux in it. Works well for everything I use it on with my 45W iron from Sears. Even the 8AWG wires soldered to traxxas plugs.
