EDS
08.08.2011, 10:36 PM
Over the past couple days I have been gradually working on the Twin Verticle Chassis Plates (TVP's). I started out with a basic drawing with dimensions I knew the Tvps had to fit into. I then made a couple copies of that drawing and taped them to the 3mm (1/8") 6061-T6 Aluminum sheet I bought off of ebay.
Once I got the basic rectangles cut out and I drew the cut at the bottom of the plates that increase the ground clearance. At this point I was ready to mount them to the lexan pieces. I won't explain the boreing and lengthly method I used to get all the holes in the right places and to make sure they line up..so i will skip to the pictures...
*Keep in mind that these Tvp's aren't even close to being finished.. once I get the motor, battery, servo,etc mounted I will take everything back off and finish the design, shorten them, cut sections out to reduce weight, and file the pieces*
The next task on the list is to cut a section out of the left TVP for the motor to fit through and also get the motor mounted up.
