08.12.2011, 03:50 PM
RCM has quite a few mounts, you might find that one for another vehicle will work. Take all the pertinent measurements from the center diff bulk (hole spacing, overall height, bearing height and size, etc.) Maybe even make a simple drawing with the measurements, then send it over to Mike.
As long as the lower hole spacing matches and the other values are close you can use a few shims, and mod or make a new top-brace. If you're lucky you might find one that will bolt right up.
