No
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
No - 08.17.2011, 12:30 AM
Originally Posted by freddy View Post
the drill will follow the existing hole, right?
Was more concern about the hardness of the pinion than getting it 110% straight, guess i just gonna give it a try. dont have an drill press, and dont want to bug other to help me
if i sand the shaft down from 6mm to 5mm, i think there will be more risk about getting it straight than drilling the pinion. atleast its better to risk a pion than the shaft.
Yes the drill bit will follow the original hole, BUT a handheld drill will not give you a clean straight hole creating vibration. Sanding the shaft can work better and if you have to drill out the pinion use a drill press to keep the hole straight.
SUPERMAXX YOUR LIFE.
