Originally Posted by magman
well, i vote for the 8T as my truggy, mbx5t, is by far my favorite in my stable of 6 rc's. I also have a crt.5 which actually is my daughters. I do not like the frailty of the arms in particular of that truck hence why she has it now. Even on a 2s set up she manages to do a fair amount of damage.....i keep a spare crt.5 just for parts for her.
The GR Revo is my second choice except I would do a true CD set up.
Good luck!
Like i said i know the 8T will handle it, I beat one all to H#!! running nitro. I raced an O.S. .21 v-spec against .30's and rarely lost.
I disagree with your opinion on the CRT.5, One i had in nitro was a tank, every bit as tough as the 8T, Actually made the 1/8 truggies nervous when i threatened to enter it. Oh! i was running a 5 port o.s .12 tr in it, insane little truck. It is possible converting to brushless might show some weaknesses
Originally Posted by BrianG
If you decide on a CRT.5, I have one for sale...
If you have it posted here, can you link it to me? Might be interested
Originally Posted by Overdriven
I'd do the 8T, I liked it alot more than the Revo. But if you decide on getting the revo up and running I'd install a center diff instead of the tranny. Btw, the only Ofna diffs I know of with a 5mm pinion are the LX series. But I doubt the ring gear and diff cup will fit in the RC-M conversion cases.
Like said earlier figured the 8T might get a few more votes. The reason for running the 2250 in this setup, it should run lower amps. This motor was designed for pushing big boats and possibly 1/5 scale cars, should barely know the 8T/Revo is even there at 4-5s lipo's.
thanks for the input, the 8T will possibly be cheaper to build, only need the motor mount and battery box
