j.f.s
08.20.2011, 01:22 AM
Originally Posted by crazyjr View Post
Do you do this with the battery plugged in or not? I have tryed everything to plugging in with link hooked up to switching off and switching on. Also, i can do this without the castle link? Or need to go through the reciever wire. remember the maxx has that mini USB on the side. Anyone from Castle wish to chime in?
Can't answer your question about connecting the USB directly to the ESC since I don't own such an ESC. I assume it should work though since you can change every other option using that port, right?
I change my settings without having the battery connected. I hook them up when I'm ready to perform the motor test.
