snellemin
2 KiloWatt RACER
snellemin's Avatar
08.22.2011, 12:42 AM
Did a few test runs again with 0 degrees timing. Temps where much better.
Run #1 measured with Eagletree V4 150A.
Tekin RX8
0 timing
Stock brakes
4s hardcase Acepow
20T pinion
Ofna GTP 47 spur
Peak Amps 157.35A
Peak Watts 2069W
Continuous Amps 22.08A
Continuous Watts 324W@14.68V
129F
Run #2 measured with Eagletree V4 150A.
Tekin RX8
0 timing
Stronger brakes
4s hardcase Acepow
23T pinion
Ofna GTP 47 spur
Peak Amps 162.21A
Peak Watts 2039W
Continuous Amps 27.67A
Continuous Watts 400W@14.44V
142F
So it looks like I can go up another tooth with the pinion and still be good with temps.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
