08.22.2011, 01:34 PM
I appreciate you saying so, Magman. The truth is that while my kits may appear fairly simple in design, this simplicity is part of their genius(I work to make things work as seemlessly as possible). I am quite confident that any of my kits will have more compatibility with available equipment, optimum and expansive adjustment opportunities(gear mesh, for example, is optimized for various ratios within each specific kit) and optimum weight consideration(total weight and also weight bias for superior handling) vs other available components and/or kits.
I don't simply make a generic motor mount and call it a conversion, but rather spend considerable time ensuring that the customer can install most any motor he or she may have, along with their desired gearing, batteries, etc. - of course each individual car/kit has inhernt limitations, but each design is optimized within the available parameters of the car from motor choice, to body clearance and weight bias and most everytihing in between. The best case scenario involves the end user simply installing the kit and racing, with as little drama as possible and with successful results. I don't do sexy advertising or elaborate product descriptions(maybe I should?), but my offerings do work as intended and are born of my passion for the hobby.
