Thread: Too much slip
cmac
cmac's Avatar
08.23.2011, 10:37 PM
I just tried to tighten my wave springs down some more and I just broke them. My truck will most likely be even heavier than your truck so I might be in the same boat. I am interested to see if you will need extra wave springs. What holds the wave springs together? Are they glued, soldered, or welded? Both spring came apart at the overlap sections. everything else seems to be OK. I have more springs on the way, but if I can fix the ones I have I would like to.
