Originally Posted by suicideneil
I'd have thought the UE knuckles & a-arms had their own specific turnbuckles to use as they are non-standard lengths compared to the stock old or new emaxx turnbuckles, so far as I know. I'd set the knuckles straight ahead, and the steering bellcranks centered, then use some calipers or something to work out the length you need and see if anything matches pre-existing options; you can also make your own turnbukle to find the required length using some threaded rod & a couple rod ends ( trim rod as required until the steering knuckles & bellcranks play nice )...
I'm going to try a set of these because I cut them to what ever length I want.
http://www.google.com/url?q=http://w...PgMFJBjwufZUMQ
Do you have any experience with these?
