Thread: Too much slip
cmac
cmac's Avatar
09.03.2011, 02:21 PM
Given it was designed for racers with lighter vehicles, your setup may just be a bit too much for the slipper, in which case add an extra wave spring. You shouldn't run out of thread then.
So I would like to know if you tried the third wave spring and if so did it work?,or did you get it worked out some other way?
