09.06.2011, 12:22 PM
That hub looks nice. Bolt on is easier than modifying an extended 23mm hub and wrapping it with aluminum tape like I suggested too! Is the piece on the right the nut or an unfinished hub? I'm confused by the hole drilled in it, set screw?
