NickRummy
NickRummy's Avatar
09.06.2011, 12:29 PM
The piece to the right is a drilling fixture. The axles require a new hole to be drilled in them for the baja 4mm pin. Basically slide the xl axle into the fixture, put a wheel nut on to hold it in place and then drill a hole through the opening in the fixture.
