EDS
09.09.2011, 02:05 AM
Today I got the steering servo mounted.. I was going to just cut a rectangle out of the battery box..and just bolt the servo directly to that..but I didn't think it would be stiff enough. So I cut a aluminum piece and then cut a lexan piece and bolted the lexan piece standing up on the aluminum... I then bolted the lexan to the Tvp and the servo to the aluminum and also to the battery box. No flex here..
Now it's come to that point into time where I have to tear down the entire truck and run thru everything... fill the diffs, trim the TVP's , cover the aluminum pieces in flat black vinyl, make sure everything is spinning freely, etc
Once I get all the nit-picky stuff done I will be putting it all back together...mounting the esc and rx , wire everything up, take care of any last minute touches, and finally paint the body.
