mamba max1
mamba max1's Avatar
09.09.2011, 09:41 AM
Originally Posted by crazyjr View Post
Is the motor the ESP black magic motor? I remember those being torque monsters. If you run it at all, you might need the aluminum idler gear, even with the old new battery. I had a rebel esc, Still do. It's one step up from the F10 you have, tough esc and will live long, even with abuse
I have very little info on the motor. I have searched high and low and have found little about it. Having a name of "black magic" doesn't help the the search function either.
I don't think there is an aluminum idler for the tranny. I did get the upper steel gear though. When I run, I will make sure the clutch is loose anyways. :)
