Aussie Nerd
09.18.2011, 09:19 PM
Went out for a crawl on Saturday with a couple mates for it's first test drive. It wasn't 100% finished yet, but almost there. I decided to run the BCs and eritex wheels simply because I made my weights to the absolute maximum size possible and they no longer fit VP wheels. I had my old faithful firm inner, soft outer CI foams from my rovers, but I believe they are a bit firm. The other problem I had was the Charlotte's and the BCs would not play nice and I ended up pulling 3 beads (and this is after about 4 goes at mounting the things properly). The slot in the eritex wheels is simply to small to hold any bead properly IMO. So they will be getting lathed shortly.
Now for the good news. Everything pretty well performed faultlessly minus a couple loose bolts and nuts. The mini pullers and wheelspeed to boot and seem to be able to power the rig around most things with no drama's or temperature problems. They will stall in hard digs or binds, but I guess that is to be expected. The shrunk mamba micro's had no problems handling the pullers, and most of the time they barely felt warm. And finally the futaba servo is simply awesome, I was running it on 7.8v and it was only warm, but had enough power to swing the rear end of the rig around no worries. I think I only managed to stall it once, and it was really wedged in.
Onto the chassis. The rollover, as expected, was excellent. Thanks to my "brilliant" driving and a bit two much wheelspeed with the pullers I tested this quite thoroughly The handling was quite good also, for everything from precise slow speed crawling to going flat out up rocks and doing backflips. This chassis will definitely be staying put with very little changes. Hopefully CrawlerX should have them released shortly for everyone to get their hands on them.
Pictures, well unfortunately I was having to much fun 'testing' to take any pictures or video. So I'll just have to end with a couple I took at the end of the session. You can also see the final design for my knuckle weights.
Kieren
