09.22.2011, 11:59 AM
That's a thing of beauty for sure, really did come together nicely.
Only other thing I would say look at is the right-rear knuckle, the camber angle looks to be a bit out of whack ( top the the wheel is leaning outwards, should be sitting level ideally & pointed inwards when viewed from above ( 1.5 degrees toe-in on both sides, front wheels should be parallel & sitting level too ).
I'm also looking at how you mounted the shocks in different holes on the towers- ideally both shocks on each side of the tower should use the same hole, with a long screw going all the way through both shock caps & mounts ( 2 shocks on one screw )- something about 50mm long should work.
Otherwise it's a work of art....
