09.27.2011, 04:42 PM
Generally speaking, yes - as long as the appropriate wind is used for each voltage. (1/2 the kv for double the voltage). A given motor will certainly have its "ideal" voltage and current range, though. The "best" motor for 5s use at the required power output isn't likely the the "best" motor for 10s use at the same power level.
