freddy
09.30.2011, 05:24 PM
Had my first run and noticed a few things.
First the wires got extremely hot, also the connectors got hot and the esc fan was constant on, is this motor so power hungry that normal (fake) deans dont cut it?
The motor got 60C (140f) on this little test run, the end bell was the hottest place, so i believe this has to do with the hot wires and esc.
The battery even with the hot wires where not unusual hot, like 30c (86f)
Running 6000mah nano tech 25c
On the stock 1515 the esc and wire temp where normal(wire ambient ore close to ambient).
Regarding gearing, running the High speed idle and 22t pinion with stock spur it was almost the same speed as with 1515 and stock gearing,, mayby slightly lower. gonna try some bigger wheels ore an tires like the terra pins ore somthing like that.. really need some suggestion regarding that.
[YOUTUBE]wFAVi8loGGs[/YOUTUBE]
[YOUTUBE]nPSNfZrnkLo[/YOUTUBE]
(it was slightly hard to film and drive at the same time)
