Originally Posted by a6m532
Hi Freddy,
You sure it is pulling more current ?. But from what i have learn from this forum, it seems that the general conception is that by using a lower kv motor and gearing to the same speed as a higher KV motor. You will get a cooler and more effiency motor. Not sure if my understanding is right
that was my thought to
have to correct myself, it depends on the gearing and voltage. if the car have the same speed and same voltage it would pull about the same. as this motor is bigger and the same speed and voltage it will draw more current
