Calm down
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Calm down - 10.03.2011, 11:44 AM
Calm down Thiessen dont get mad because we are trying to share our advice with you. You started this thread asking us for advice and info, but your continuing communication seems to be that you have already made up your mind. Please share with us why the resolution on a laptop is so important, when you stated that you would be connecting this to your home theater system, which would pretty much make the resolution on the laptop itself a none issue. Plus as stated one can add HDD's and memory much cheaper after market through suppliers, rather than paying top dollar from major PC dealers. If you are hell bent on spending $1800-$2000 on a laptop regardless of the great info being supplied on here, than why did you ask? Please don't take it so personal as we are only trying to help to advance your research and maybe save you a few bucks in the process as you requested. There are ways to avoid paying through the nose for PC gear that you can get much cheaper through other venues. I did not come in here to battle with you, but to try and help just like a few others are.
SUPERMAXX YOUR LIFE.
