modules -
10.05.2011, 02:24 PM
mistercrash - The module pricing would vary slightly based on size and level of completion. There is a bit of work to get the wall-wrap and it is dependent on size of the batts(have to make a form, then heat the plastic and bend around the form). the upper and lower pieces and lid is the easiest part now, as I should be able to modify my existing design to fit most pack configurations(within reason). The copper plates are easy enough to machine, but the screw posts must be soldered on with a torch - not too difficult, but takes some time and skill. I really haven't done enough to have a good system worked out, so I can't really accurately quote a price yet(not sure on the time aspect). I plan on making another set for 7s packs soon and will get a better handle on the process the 2nd time around.
snellemin - in all fairness, my bike started life as an electric bike from its inception. Most ebikes are cool, though. I think crossing the lighter weight of bicycles with the motorcycle design cues is the way to go - I want to get a supermoto setup for this bike one day and maybe register it for banging around town(I do occasionally cruise on some streets around and always get rubber-neckers). :)
hippie - I didn't make the bike - I only converted it to its current state. I would like to develop an electric frame in the future, though - something that uses widely available parts, but is purposed for e-power. It won't be this week, though. :)
