Pdelcast
Pdelcast's Avatar
10.07.2011, 06:30 PM
Impressive it is. What is more impressive, is that Patrick himself is giving me advice on how to make it work on my cheap lipo's. Time to get a Hyperion 45C 5000mah pack, if I can find one in stock.
The C40-5L Hacker and Neu 1506 6800kv motors are easier on the batteries, compared to the B50S Hacker. Timing on the Hackers is set for 5 degrees and the Neu at 10 degrees. The current GenAce battery pack is only good up to 60% capacity. After that the CRT.5 is just slow.
Hey, one more thing...
ADD some capacitance to the battery side of the ESC. You are probably really stressing the capacitors. If they fail, the controller will go BOOM.
Patrick del Castillo
President, Principle Engineer
