10.12.2011, 11:39 AM
The default setting is 4mm between the adjustment nut and the chassis IIRC. I believe mine is set to 6 or 8mm.
Forgot to mention that I use an external BEC, the Castle 10A version, to save some load from the ESC. The Savöx servos are known to be amp hungry. I believe the MMM BEC provides 3A max.
