Gustav
Gustav's Avatar
03.26.2006, 04:58 PM
Originally Posted by cabking
I personally don't find it a PITA to work on though, as all the bits including the engine +header and filter still attached, gearbox and shocks can all be striped out without removing the cage:dft003:
If you can do that with it on then it's way easier to work around than the LST cage which is the only one i have experience with,with that one you have to remove it all the time.
They're easy enough to bend straight again if you bend it.
