Knez
Knez's Avatar
10.31.2011, 08:27 PM
I think i would take a set or 2 of your ext aarms and towers too if it proves to be worth it!
Will check the KD site :) and thanks for info!
Well if we are taking about GD shocks than the springs are a bit hard, didnt tested them, but i got a feeling i will have to order softest i can get.
Also shocks with no spring...if i put shaft totaly in...it comes out by it self to total extended lenght.
If we are talking about flux shocks "A720" i got on these 1 harder than stock, i think yellow rated springs.
Small update, I got rid of 6,5mm connectors and now got only 6mm from HK.
Also made 4 holes in esc plate and mounted esc directly on.
Xerun 150A is great for first test and runs very very nice.
Got no card at the moment but cells are on outo cut off 3.2V per cell.
Had a great 23 min of run at the night with lights on.
I like the size of the esc, small but strong.
Here is how i mounted wing to friends 5b to get an angle for a wing.
Cutted 2 long shafts from body mount and made 2 holes wich those 2 shafts where put thrue and secured with body clips..2 Bclips up and 2 Bclips down. We can actually put more angle to the wing (set the wing angle) if 2 cutted shafts are slided/moved more up (out of the towers) or if slided/moved more down (in to the towers).
These 2 shafts push the rear of the wing more up in this case.
No need for 2 body posts between the body mount and tower as body mount is leaning on the tower ears ( tallest part on towers, where you put shock upper shcerw thrue)
Also must say wing is no longer moving, it is secured now.
FG wing, perfect fit with stock holes.
Me and my english...lol
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
