nastety92
11.11.2011, 03:47 PM
Originally Posted by brian015 View Post
Is that the bearing from the pinion gear? It seems to have exploded - you should buy a new bearing.
Yes I'm pretty sure just the bearing came apart causing this problem. I was just confused while looking at it at first. Now I can see the bearing is in multiple pieces causing my problem.
I'm going to rebuild the rear diff with a few new pieces while I'm in there.
Thanks for the help,
Nick
Tamiya TRF801Xt-e
