RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.14.2011, 06:24 PM
Those couplers were specifically for the RC-Monster v3 revo hybrids - the pinion shafts are 8mm at the bearing and 5mm at the drive cup. The couplers would need to be drilled and reamed through to 8mm and likely a new set screw hole would need to be machined to make them work on the LST diffs - easy to do if you have a lathe and drill press, but not so easy with normal hand tools.
