Thread: Power supply
11.16.2011, 11:08 AM
Originally Posted by captain harlock View Post
BTW, just today I came to know that MaxAmps sells a very powerful( 47A, 1150watts) power supply for a reasonable $150+. Has any of you tried their PS?
Yeah, they have two models, a 12v and a 24v. Both versions just use the same HP power supply modded as found here. The 12v version is basic enough, but I'm not sure if they modded the 24v version properly (decoupling the output ground from the case/earth ground). Either way, it's a fairly cheap high power solution if you don't want to mod your own, but you'll be paying around $100 more for that convenience (those supplies can be had for around $25).
