11.28.2011, 05:34 PM
It seems that most attempts at very high speeds boil down to "throw more power at it". Sure, you can make a brick fly with enough power. But someone should come up with a better way to utilize the power we already have. Gearing up high enough to achieve 100mph+ speeds is hard on the ESC, and you still have to wind that motor out. Two-speed transmissions aren't great because of that torque change at the shift point (tried it - didn't like it). Too bad someone couldn't come up with a reliable, lightweight, and relatively inexpensive CVT setup; would provide better off the line control and power, yet keep the acceleration smooth and motor in its ideal "power band" to take full advantage of a motor's capabilities without stressing everything so much.
