crazyjr
crazyjr's Avatar
11.30.2011, 12:28 AM
Originally Posted by PBO View Post
I'm not familiar with T4 CF chassis although I'm guessing it's the carbon variation rather than the carbon fibre...??
The only available T4 CF chassis is the factory team molded one
It might also mean you're considering gluing cut pieces 'end on' to the sheet? this isn't the strongest way of completing a join but if you take a few cues from boat guys & drill a series of small holes along the bottom edge for the resin to run through it should provide additional strength basically what i am planning to do, I may even go with alumnium standoffs If gluing the CF isn't strong enough
Comments in red in quote
