12.02.2011, 04:03 PM
Good question - I'm not really sure how CA & epoxy will react
What I would do is mix epoxy & 'glue fibers' (you could use talc powder) to stiffen the mix until it's as viscous as cold honey, then glue your components with that (You will need to add black pigment powder if you don't want to see the glue) & 'cove' the excess away using a tight radius to leave a smooth fillet
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
