12.09.2011, 12:39 PM
Hi.I've had an MMM in mine a couple of years,never had one of them twist like that,it's always the driveshafts that go to the wheels that braek at the cross pin.BUT I've figured out a "cure" for that. Take the part that goes into the wheel.put the threaded end in a drill,open up the plastic where it fits by using it as a drill bit.Get a galvanized nail,cut it so 3 mm pokes out of the plastic driveshaft.Drill it out with a 1/1.5mm drill,Put it all together,then peen the drilled out end out. Sorted:)
