cmac
cmac's Avatar
12.17.2011, 03:35 PM
Originally Posted by mothman View Post
I was told that Ofna measures their dogbones according to the overall length, not pin-to-pin. I might be wrong. Please let me know once you get the parts.
And as for the link on Kershaw Design, the dogbone is not 120mm.. it is only 114mm, according to Dan, the owner.
Yes, you are correct the 120mm measurement is end to end not pin to pin. It turns out that even with that I still had to grind the ends on my bench grinder and now the back drive shaft has just the perfect amount of play.
