12.21.2011, 11:14 AM
If you do a lot of jumping, you may want to keep the nitro brace if you can. The mount works awesome, but the chassis does flex, and that messes with the mesh when it does. And when the mesh changes, you could get chewed gears. The nitro mount and/or the optional Traxxas bracing plate makes the chassis much stiffer around that area.
