01.07.2012, 08:01 PM
What motor, what voltage and what tires are you going to run?
For the speed calc, you're going to use the "E-Maxx 3905 1 speed or 2nd gear" option. I'd recommend running a 65T spur, you're going to need it to make up for the Lower ratio in the HB diffs and keep the pinion a normal size. Btw I run a 65t spur on my 3905/8 and I cant use a pinion smaller than about 18t with a castle motor because the motor will hit the trans case before the mesh gets tight enough. On 6s with a 2200kv, 24/65 gearing with the 3908 tires you'll be at 55mph before you factor any tire ballooning.
