Originally Posted by bruce750i
The top of the spur appears to be slightly leaning away from the motor mount.
+1
Your spur does not appear to be exactly vertical - this means your mesh will not be perfectly aligned - and your pinion will be forced toward the end of the motor shaft and eventually come loose.
