brian015
brian015's Avatar
01.10.2012, 08:13 AM
Originally Posted by bruce750i View Post
The top of the spur appears to be slightly leaning away from the motor mount.
+1
Your spur does not appear to be exactly vertical - this means your mesh will not be perfectly aligned - and your pinion will be forced toward the end of the motor shaft and eventually come loose.
