mothman
01.14.2012, 04:37 AM
The ultimate Hybrids are the same as the standard hybrids but include diffs and the needed shim to make the diffs fit - the diffs are smaller than the earlier ofna/Hot Bodies diffs the Hybrids were originally intended for. The diff pinion is 8mm at the bearing and turned down to 5mm at the drive cup - similar to Mugen, AE, Losi, etc. :)
What diff will be included? If they are smaller that the ofna/HB, should they be weaker? Or they are better?
