Ran into a problem today. With the Tekno carriers you must install their stub shaft on your axel or cvd because it is larger in diameter. Im running the Traxxas cvd's and you can't remove stub shafts from them. My only option is to find cvd's with removable stubs, or just get rpm carriers. Im just getting rpm carriers. A little disappointed because the tekno's look really good and look like they would hold up to anything. I will use them on a future build I suppose. I did get the rear all done since Im running the tru-track on it. Now I have to wait for carriers to arrive.
This shows how you install the Tekno stubs onto stock traxxas axles and how the traxxas cvd stubs aren't removable, or atleast not in a way that will allow you to use the Tekno stubs
[/IMG]
[/IMG]
[/IMG]
[/IMG]
