Revorocks
01.20.2012, 05:10 PM
It sounds to me like something is dragging.
When you took it apart, might you have swapped the brass spacer bushings front to back?
I put them back just as I took it apart. If I put them back the wrong way round would the shaft not be able to move back and forward a significant amount?
Took it apart again to check and the smaller length brass spacer is on the front (pinion side), the longer one is on the back.
Is this correct?
E-Revo Brushless MMM + Neu 1515 5S
Hyper 7e MMM + Neu 1717 6S Speed Project
