Knez
Knez's Avatar
01.20.2012, 09:25 PM
Hi all, here some buddy codes if anybody needs anything from here even cheaper than it already is.
Budy Codes:
________________
Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g
http://www.hobbyking.com/buddy.asp?c...2-FD211DAA39DB
________________
Turnigy S8166M Servo 154g / 33kg / .21sec
http://www.hobbyking.com/buddy.asp?c...8-04267E872C13
________________
Turnigy AA LSD 2200mah Low Self Discharge (ready to use)
http://www.hobbyking.com/buddy.asp?c...9-762DEF0B55DA
________________
Turnigy nano-tech 4500mah 6S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...4-D3308CA7D02B
________________
HXT 6mm Sprung Gold Connectors (10pair/20pc)
http://www.hobbyking.com/buddy.asp?c...9-05296F1BE68F
________________
Turnigy Heat Shrink Tube 10mm BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...E-9574EBB4E7EC
________________
Turnigy Heat Shrink Tube 10mm RED (1mtr)
http://www.hobbyking.com/buddy.asp?c...3-CF01780BA483
________________
Insta-Flex Flexible Thin CA 1. oz
http://www.hobbyking.com/buddy.asp?c...C-F50183706A4D
________________
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...9-539F29EC3043
________________
Parts Container 165x90x40mm
http://www.hobbyking.com/buddy.asp?c...D-B4DAEF9BBBDE
________________
Wire Mesh Guard Blue 6mm (1mtr)
http://www.hobbyking.com/buddy.asp?c...0-1C411E71BE8F
________________
Wire Mesh Guard Red 6mm (1mtr)
http://www.hobbyking.com/buddy.asp?c...7-766949578C20
________________
6inch Spring Clamp Tool
http://www.hobbyking.com/buddy.asp?c...4-ACE1AF5850BD
________________
5pc Rigid Cleaning brush set.
http://www.hobbyking.com/buddy.asp?c...7-2826ECFBED2F
________________
Turnigy Long Shaft 4pc Hex driver set
http://www.hobbyking.com/buddy.asp?c...1-8D5B98646774
________________
Turnigy 2mm long shaft Hex Screwdriver
http://www.hobbyking.com/buddy.asp?c...4-99E07C016B35
________________
Front Tire Set - A2003T (2pcs)
http://www.hobbyking.com/buddy.asp?c...C-B8F13AFF94E9
________________
http://www.hobbyking.com/buddy.asp?c...7-8B7347F3D440
________________
TURNIGY Plush 40amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...B-64B6A6274BB7
________________
TURNIGY BESC Programming Card
http://www.hobbyking.com/buddy.asp?c...3-D1A50C8A5D36
________________
Hobby King 401B AVCS Digital Head Lock Gyro
http://www.hobbyking.com/buddy.asp?c...0-8883058A0959
________________
GT450PRO Drive Gear Set 11T/13T 3.15mm
http://www.hobbyking.com/buddy.asp?c...C-245EF14E8372
________________
Turnigy Battery Strap 330mm
http://www.hobbyking.com/buddy.asp?c...6-A3B59DF1E6C9
________________
Roof Guard / Roll Cage Baja 260 and 260s
http://www.hobbyking.com/buddy.asp?c...8-6495DCC75051
________________
Regards,
Knez
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
