Originally Posted by pinkpanda3310
If you used castle caps and a bec that would help the esc.
I take it you don't like Brian's no spark idea?
And mechanical brakes! that helps.
Brian says that CC says not to use a resistor on a Mamba esc. If I remember correctly, it's been stated that it's Ok to use it on a Mamba if the esc is turned off when you charge the caps through the resistor - then turn the esc on.
