Originally Posted by devious1
Just for sh#$'s and giggles will a 56mm motor fit  with the RC monster mount or will i have to shim the center diff mount?
If i have to shim can i just use some stainless steel washers?
or should i use dedicated spacers of some sort?
or is it just plain overkill?
You could shim to clear the chassis with the motor - but you would have a very difficult time getting a reasonable pinion gear to mesh with the spur - so yes, I'd say that 56mm diameter is too much for a Muggy.
Edit: also mounting holes are spaced too wide for standard motor mounts.
