data log rate
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
data log rate - 01.26.2012, 11:40 AM
Kirkinsb - 2 samples per second data rate explains your low numbers for sure - you are simply missing the microsecond peak currents that happen. In my experience, the peak draw will ramp down very quickly once the car is rolling - a 200+ amp spike could be down to 120 amps within the same second. 2 samples/second frame rate will not show this, though. I understand that a higher frame rate will result less log time, but it will also yield higher data resolution so you can see more detailed data, albeit for s shorter time. Besides....do you really need to log the entire run every time? Please maximize your frame rate, gather some data, and report back. You can always change the frame rate back afterwards, but I think you will be surprised at what you see.
Also, while the Baja is a larger, heavier vehicle, it also typically is used under a higher voltage and will have less traction than an overgeared Muggy(4wd) with large, heavy tires. On the surface, logic may say that a car that is half the size will draw half the current, but in truth, there are many variables that will quickly dispell this logic. Also, a throttle "blip" can be no different than a full on drag race launch, but over a shorter time period. The actual peak current happens over a very short time period(1/10 second or even less) so it does not surprise me to see 200+ peaks on a heavy, overgeared 4wd monster truck.
magicald - The highest log rate will give you the highest resolution. In reality, the average draw is typically fairly low, but there are microsecond peak currents that are very high. Personally, I have only used the highest available frame rate, as I normally am only logging data when I am trying to dial in a setup or test a component(battery, motor, etc.). The highest resolution will provide the most information in a short period of time. The beautiful thing is that you can change the frame rate! I think it is wise to maximize the frame rate occasionally to properly visualize the truest data, but there is nothing wrong with a lower frame rate to gather more general data over a longer period.
In my opinion, you simply can't draw any accurate conclusions from data logged at different frame rates - logging at a low frame rate will mask peaks.
