03.25.2005, 04:32 PM
Limit your down travel. Your arms shouldn't droop low enough to cause this. You can move the shocks so the down travel is less (move upper part of shock towards the inside of the truck) . You could also move the bottom of the shock outwards to accomplish the same thing. If these tips don't work, you will have to install limiters inside the shocks, but you should be able to work it out.
