Kcaz25
Kcaz25's Avatar
02.03.2012, 03:51 PM
Update: Well my day at the track was a bummer. I cracked a titanium gear in my servo after 5 mins out on the track.
I got This Savox Servo from the hobby shop at the track the next week after
HERE is the track.
Here are the stats of the servo.
Specifications:
Speed @ 6.0V: 0.15
Torque @ 6.0V: 277 oz-in / 20 kg-cm
Weight: 52.4g
Bearing: Dual
Type: Standard
Gear: Titanium and Aluminum
Case: Aluminum Heatsink
Right now it seems even better than the old one that I had. From Hobbico. CS-170
SPECS:
Titanium gears
Aluminum heat sink
Speed: at 4.8V = .19 sec @ 6V = .15 sec
Torque: 4.8V = 250 oz-in (18 kg/cm)
6V = 333 oz-in (23.97 kg-cm)
After that I hit the track and was finally able to put down about 10,000mah. It was great!
