Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
02.05.2012, 12:58 AM
Originally Posted by bruce750i View Post
I would use a little higher cutoff like 3.4v if you have a c-link.
Check each cells voltage in that pack for abnormalities.
Did the puff reduce after charging?
I've already increased the cut-off to 3.3v vs the stock 3.2v.
I did read that charging a pack can reduce the swelling sometimes. Its currently balance charging at .5C right now. And that sometimes it can take several cycles.
I don't have a volt-meter right now. I suppose I should get one of those nifty little testers that report back on each cell so I don't have to probe each one.
___________________
However, I first charged the non-swollen pack, and after balance charging it at 1C its swollen NOW. It wasn't when I started charging it. So I'm thinking I may have to junk both packs unless I want to risk running them and having my truck go up in flames. I've heard that some people continue to run a slightly swollen pack without issue. I'm not sure if I want to take that risk.
I will see what the vendor will do for me. I ran the 3S lipo's in parallel with the same voltage cut-off setting as the 2S and those are fine. But the twin 2S packs are exhibiting problems.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
