I'm back finally!!! Need help with a feiago 8s/mgm 8012.
bigair78
I'm back finally!!! Need help with a feiago 8s/mgm 8012. - 03.30.2006, 12:53 AM
Ok, I have been messing with this system for a while. I traded it off and then traded back. I feel like a kid for doing trades like that, but anyway. Now I have it programed up, using Batfish's instructions.(Thanks You batfish) Well it works good but it seems to be slow on start up and then really fast on top end. Almost like its running on a dead battery and BOOM it's off like a rocket. I have a 5.5 in a rusty and it has pep on take off and on top end.
This is the programing I used:(Thanks again Batfish for "dumbing it down" for me)
Plugged it in.
Turned my radio on.
Pressed full throttle.
Turned ESC on.
Held full throttle until the ESC beeped 3 times.
Pushed full reverse until the ESC beeped once.
Moved to neutral until the ESC beeped 2 times.
Pushed full reverse once (set paramater 1 to "CAR Mode"), moved to neutral.
Full throttle, moved to neutral.
Turned ESC off.
At least it is not shutting off everytime like before.
Oh and it's in a Traxxas Stampede with gearing 17/87.
Thanks in advance guys.
